Page Break
Add a page break to the report.
- Right-click at the Report or Chapter level and select Figure 1.
- Below are the properties associated with the Break entity.Figure 2.
- Name: You change the name property of the break item.
- Orientation: Select the page break type. The page breaks also change the
orientation of the following pages in the exported report.Figure 3.Restriction: Section breaks are not supported on Linux.
