Use the Report tool, formerly known as Automated Reporting Director, to create and export Document and Presentation
reports from within the HyperWorks session.
Create a standardized report from a pre-defined report template that can be reused to execute and export future reports.
A template file saves the Report contents (entities and modules) and the model file data.
Report items consist of several objects that define Document and Presentation reports, such as images, text, and tables.
These entities are the basic building blocks of any report.
Explore, organize and manage your personal data, collaborate in teams, and connect to other data sources, such as
corporate PLM systems to access CAD data or publish simulation data.
execute and export future reports. A template file saves the Report contents (entities and
Before you begin, make sure the Document or
Presentation report is set up correctly in the Report Browser.
When creating an initial template, the master document path and working directory
information are saved in the template file along with the report structure for
future use. Upon loading such a pre-defined template, you are given an option to
either use local preferences, use the preferences from the report template (by
default), or shown the working directory and master document defined in the
template.
Save the report template.
From the Report Browser, click (Save) and select one of the following options:
Choose Save Report Template to save a
report template.
Choose Save Report Template As to save a
report template in a specific file location.
Load a previously saved report template.
From the Report Browser, click > Load Report Template.
From the File Browser, navigate to the required
report template and select Open.
The Report Settings dialog opens.
To only load the report tree structure and to exclude the report
parameter files, such as the model and result files, select the
Load Report Structure only checkbox.
When you want to load the complete session data, clear this checkbox
and make the correct selections for the report template
parameters.
In the Work Directory field, specify the default working directory
where the Report output files will be stored.
If the report template was not created on your machine and the
directory is not correct, click Default. This
sets the working directory to your system default.
In the MS-Office Master Document field, specify the master file used to
create the report template.
If the master file is common to all systems, you can retain the
selected file. Or, you can choose a different master file.
Click Default to select the default report
template that exists in the Report folder as the master
document.
Click Load.
All required files and the tree structure are loaded into the
session. You can now execute and export the report files.
