vidINote GetBorderThickness
Gets the border thickness of the note.
vidINote_handle GetBorderThickness
HyperWorks Tcl Query
Returns the border thickness of the note.
None.
Gets the text alignment for the note.
Gets the attachment method for the note.
Gets the filename of any bitmap displayed in the note.
Gets the text color of the note.
Gets a handle to an hwIFont interface for the note font.
Gets the title of the note.
Gets the note position.
Gets the (unevaluated) text of the note.
Gets whether the note is displayed or hidden.
Sets the text alignment for the note.
Sets the attachment method for the note.
Sets the border thickness of the note.
Sets the text color of the note.
Sets the title of the note.
Sets the note position.
Sets the unevaluated text of the note.
Sets whether the note is displayed or hidden.
None.
