plt3DIBarChart GetSymbolStyle
Gets the symbol style of the bar chart.
plt3DIBarChart_handle GetSymbolStyle
HyperWorks Tcl Query
Returns the symbol style index of the bar chart.
None.
Returns the bar chart color index.
Gets a named meta-data value previously associated with the chart.
Sets the bar chart color index.
Sets the symbol style of the bar chart.
ON THIS PAGE
None.
ON THIS PAGE
