Multiplication C-only Filter Example
The following C source code multiples two vectors together and returns the resulting vector.
// File      : mcf.c
// Date      : 1/8/96
// Copyright : Altair Software Development, Inc. 1996
// The multiplication C-only filter
#include <stdio.h>
#include <stdlib.h>
#include "ipclib/base/altair_ipc.h"
int main(argc, argv)
        int argc;
        char *argv[];
    AltairIpcVectorList  vec_list;
    double              *new_vec_list;
    double              *first_vec_list;
    double              *second_vec_list;
    char                 msg_buff[1024];
    int                  cnt;
    * You must do this before anything else...
    if (AltairIpcParseCommandLine(argc, argv) != ALTAIR_IPC_SUCCESS)
        exit(1);
    AltairIpcPutMessage("Child [1]");
    if (AltairIpcGetVectorList(&vec_list) != ALTAIR_IPC_SUCCESS)
        return -1;
    AltairIpcPutMessage("Child [2]");
    if (vec_list.num_vectors != 2)
        sprintf(msg_buff, "Expecting only two vectors, got %d",
            vec_list.num_vectors);
        AltairIpcPutError(msg_buff);
        return -1;
    * To make this code more readable I'm going to use less
    * pointer indirection by using the following variables.
    first_vec_list = vec_list.vec_val[0];
    second_vec_list = vec_list.vec_val[1];
    * Multiply them
    if (vec_list.vec_cnt[0] == vec_list.vec_cnt[1])
        AltairIpcPutMessage("Multiplying input vectors...");
        new_vec_list = malloc(vec_list.vec_cnt[0] * sizeof(double));
        if ( ! new_vec_list)
            AltairIpcPutError("'malloc(new_vec_list...' failed");
        for (cnt = 0; cnt < vec_list.vec_cnt[0]; ++cnt)
            new_vec_list[cnt] = first_vec_list[cnt] * second_vec_list[cnt];
            if ( (cnt % 5) == 0)
                sprintf(msg_buff, "[%d] val = %lf", cnt, new_vec_list[cnt]);
                AltairIpcPutMessage(msg_buff);
        AltairIpcPutVector(vec_list.vec_cnt[0], new_vec_list);
        free(new_vec_list);
    else
        AltairIpcPutMessage("Returning first vector...");
        AltairIpcPutVector(vec_list.vec_cnt[0], first_vec_list);
    * Be a good boy and free my memory (even though the application is
    * about to end).
    if (first_vec_list)
        free(first_vec_list);
    if (second_vec_list)
        free(second_vec_list);
    return 0;
