HMRES_simulationopen()
Opens a simulation.
int HMRES_simulationopen(char * simulationname, int simulationid);
HyperMesh hmreslib Function
Opens a simulation.
simulationname
The simulation name of the simulation to be opened. If left blank, the ID is used to create the name.
simulationid
The simulation ID of the simulation to be opened.
Zero, if successful; otherwise, nonzero.
The ID is ignored unless the name passed is zero length. In this case, HyperMesh creates a simulation name based on the ID, which must be nonzero.
A simulation must be created before it can be opened.
None.
