HMRES_argumentsetselected()
Sets an argument as being selected. This function can also be used to change whether an argument is selected or not.
void HMRES_argumentsetselected(int index, int selected);
HyperMesh hmreslib Function
index
The index number of the argument to be selected or unselected.
selected
Determines if the argument is selected or unselected. Use:
  • 1 - If the argument is to be selected.
  • 0 - If the argument is to be unselected.
None.
