HMMOD_initialize()
Initializes hmmodlib.
void HMMOD_initialize(int layers, int node, int ecentroidal, int nodeonelement, int eintegrationpts);
HyperMesh hmmodlib Function
layers
The number of layers that hmmodlib should allocate for an element in the model.
node
The number of nodal result values to be stored, per layer, for each node of the model.
ecentroidal
The number of element centroidal points, per layer, per element, which should be stored at each element centroid.
nodeonelement
The number of node-on-element results, per layer, which should be stored at each node for each element.
eintegrationpts
The number of values that should be stored, per layer, per element integration point.
This function must be called before any other function in the hmmodlib package.
None.
