HMMOD_elementadd()
Adds elements to the database.
void HMMOD_elementadd(HM_entityidtype id, unsigned char config, unsigned char type, int numintegratepts, unsigned char uservalue);
HyperMesh hmmodlib Function
id
The ID of the element.
config
The configuration of the element.
type
The type of element in HyperMesh.
numintegratepts
The number of integration points for this element.
uservalue
User-determined value.
None.
