UGS_LICENSE_SERVER
Specifies the UG license server to use for versions 8.5 and earlier.
UGS_LICENSE_SERVER value
HyperMesh Environment Variable
Specifies the UG license server to use for importing UG files. This is required when using UG versions 8.5 and earlier.
value
The proper value to point to the license server for your system.
Examples
UG license server located at port 28000 of licsrv: UGS_LICENSE_SERVER 28000@licsrv.
None.
