HG_DEFAULT_RESULT_TYPE
Sets the default file type displayed in the file browser.
HyperGraph Environment Variable
The default file type displayed in the file browser can be customized by setting the HG_DEFAULT_RESULT_TYPE environment variable to Nastran PCH (*.pch). Upon setting the environment variable, the Nastran punch file type will be displayed as the default file type instead of the typical All Files (*.*) option.
Examples
To set the default file type displayed in the file browser, from the Windows Environment Variable dialog, select Edit and enter the following information:
None.
