HM_TIMING
Creates a file that contains HyperMesh startup timing information.
HM_TIMING filename
HyperMesh Environment Variable
Creates a file that contains HyperMesh startup timing information. This information can be used for resolving startup time issues.
filename
The name and path to the file to use.
Examples
To create the file E:\temp\timing.txt: HM_TIMING E:\temp\timing.txt.
None.
