Change the Tensor Color by Value
  1. Open the Tensor panel in the following ways:
    • From the Results toolbar, click Tensor .
    • Select Plot > Tensor from the Results menu.
  2. From the Tensor panel, click the Display tab (located in the middle of the panel).
  3. Select Value from the Color by drop-down menu.
    Applies colors to the tensors based on values and the legend settings.
  4. Click the Edit Legend button.
    Modify the legend values and colors in the Edit Legend dialog.
  5. Click Apply to save the settings.
