Change the Tensor Color by Direction
  1. Open the Tensor panel in the following ways:
    • From the Results toolbar, click Tensor .
    • Select Plot > Tensor from the Results menu.
  2. From the Tensor panel, click the Display tab (located in the middle of the panel).
  3. Select Direction from the Color by drop-down menu.
    The tensor is displayed with the colors defined by the buttons. The buttons are enabled and the default colors for the tensor are:
    • Red for P1 (Major) or XX
    • Green for P2 (Mid) or YY
    • Blue for P3 (Minor) or ZZ
    • Yellow for XY
    • Light blue for YZ
    • Purple for ZX
  4. Click the color box and select a different color from the color palette.
    The color for the tensor is changed.
