Rename a Rake
  1. From the Results toolbar, click .
  2. From the Streamlines panel, right-click on the name of a rake in the Rakes list and select Rename from the context menu.
  3. Type a new name into the Rename dialog.
  4. Click OK.
    The rake is renamed.
    Tip: You can also right-click on the name of the rake in the Results Browser tree (listed under the Streamlines folder), select Rename, enter a new name in the name text field and press Enter.
