Delete a Rake
  1. From the Results toolbar, click .
  2. From the Streamlines panel, select a rake from the Rakes list.
  3. Delete the rake using one of the following methods.
    • Click Delete (located in the lower left corner of the panel).
    • Right-click on the name of a rake in the Rakes list and select Delete from the context menu.
    The rake is removed from the list and the modeling window.
