Query Results
  1. Open the Contour panel in the following ways:
    • From the Results toolbar, click Contour .
    • Select Plot > Contour from the Results menu.
  2. From the Contour panel, click the Query Results button.
    Opens the Query panel where you can view and export properties and other information related to nodes, elements, components, and systems contained in the active model.
