Overlay Result Display
  1. Open the Contour panel in the following ways:
    • From the Results toolbar, click Contour .
    • Select Plot > Contour from the Results menu.
  2. From the Contour panel, under Result display control, activate the Overlay result display option.
    Overlays the vector, tensor, and contour results in the same window.
    Note: If all results are displayed simultaneously, available memory may be affected.
