Learn how to register a Compose/OML or python function in HyperStudy using the Preference file (.mvw), and then use the registered function for output response evaluation in the study.
Learn how to use the Operator model type to run a script that uses a combination of HyperView and HVTrans to split the solver result file in multiple result files, one for each component in the model.
Learn how to define discrete size input variables with the Lookup model. You will establish links between the input
variables imported from a parameterized file with the output responses imported from a .csv file using the Lookup model.
HS-1040: Minimization of Internal Rosenbrock Function
HS-1080: Set Up an Operator Model
HS-1090: Define Discrete Size Variables with the Lookup Model
Learn how to define discrete size input variables with the Lookup model. You will establish links between the input variables imported from a parameterized file with the output responses imported from a .csv file using the Lookup model.
