Learn how to run a simple DOE study on a cantilever beam to examine the influence of the length, width, and height
of the beam on its volume, maximum bending stress, and deflection.
In this tutorial, you will learn how to build a predictive model (Fit) for an application where only design data in a Microsoft Excel spreadsheet is available (that is, no simulation
model exists).
Learn how to use a DOE to investigate the effects of the cross sectional dimensions and joint stiffness of a truss
structure’s volume and natural frequencies.
HS-2005: DOE Study of a Cantilever Beam using Templex
Learn how to run a simple DOE study on a cantilever beam to examine the influence of the length, width, and height of the beam on its volume, maximum bending stress, and deflection.
HS-2200: Use Existing Design Data from an Excel Spreadsheet
In this tutorial, you will learn how to build a predictive model (Fit) for an application where only design data in a Microsoft Excel spreadsheet is available (that is, no simulation model exists).
