Load Step: Output Request: Data File (.dat)
In the Data file (.dat) dialog, define and edit the output requests for the data file.
Supported keywords are *NODE PRINT, *ELEMENT PRINT, *CONTACT PRINT, and *ENERGY PRINT. To open the dialog in the Load Step window, select Data File (.dat) from the tree and an output block from the Output block table.
Load Step: Output Request: Data File: Define
In the Define tab, enable the Node Print, Element Print, Contact Print, and Energy Print tabs, which are used to define the *Node Print, *Element Print, *Contact Print, and *Energy Print cards.
Load Step: Output Request: Data File: Node Print
In the Node Print tab, define *NODE PRINT for the selected Output block.
The following parameters are supported: Nset, Frequency, Mode, Global, Summary, Last mode, and Totals. Activate/deactivate the checkboxes in the tree on the Node Print tab to add/remove identifier keys in the table. The data lines added in this manner have a gray background, indicating they cannot be manually edited. You may also add user-defined identifiers by typing them directly into the table. User-defined data lines appear with a white background, indicating they are editable.
Right-click on the Data lines table to display menu options. The available options are Cut, Copy, Paste, Add row, and Delete row.
| Button | Action |
| Create/Edit... | Opens the Entity Sets panel in HyperMesh. When you finish creating/editing the set, click return. The Step Manager is updated with the new set appearing in the node set list. |
| Review | Reviews the selected node sets by highlighting them in the HyperMesh graphics. Right-click on the Review button to clear the review selections. |
| Update | Updates the HyperMesh database with the data lines defined in the table and the parameters. |
Load Step: Output Request: Data File: Element Print
In the Element Print tab, define *Element print for the selected Output block.
The following parameters are supported: Elset, Position, Totals, Frequency, Last mode, Summary, and Mode. Activate/deactivate the checkboxes in the tree on the Element Print tab to add/remove identifier keys in the table. The data lines added in this manner have a gray background indicating they can not be manually edited. You may also add user-defined identifiers by typing them directly into the table. User-defined data lines appear with a white background, indicating they are editable.
| Button | Action |
| Create/Edit... | Opens the Entity Sets panel in HyperMesh. When you finish creating/editing the set, click return. The Step Manager is updated with the new set appearing in the element set list. |
| Review | Reviews the selected element sets by highlighting them in the HyperMesh graphics. Right-click on the Review button to clear the review selections. |
Load Step: Output Request: Data File: Contact Print
In the Contact Print tab, define *CONTACT PRINT for the selected Output block.
The following parameters are supported: Nset, Master, Slave, Frequency, Totals, and Summary. Activate/deactivate the checkboxes in the tree on the Contact Print tab to add/remove identifier keys in the table. The data lines added in this manner have a gray background, indicating they cannot be manually edited. You may also add user-defined identifiers by typing them directly into the table. User-defined data lines appear with a white background, indicating they are editable.
| Button | Action |
| Review | Reviews the selected node sets, main surface, or secondary surface by highlighting them in the HyperMesh graphics. Right-click on the Review button to clear the review selections. |
Load Step: Output Request: Data File: Energy Print
In the Energy Print tab, define *energy print for the selected Output block.
The following parameters are supported: Elset and Frequency.
| Button | Action |
