Load Step: Inertia Relief
In the Inertia relief dialog, define and edit the *INERTIA RELIEF card.
To open the dialog in the Load Step window, select Inertia relief from the tree and a load collector from the Load collector table.
Load Step: Inertia Relief: Define Tab
In the Define tab, define * INERTIA RELIEF cards.
Activate the Inertia relief checkbox to make the *INERTIA RELIEF load active for the current load collector.
There are two data line options available:
Free direction
Integer list of degrees of freedom identifying the free directions
Reference points
Global X, Y, and Z-coordinates of the reference point.
Click Update to activate the data line selection in the HyperMesh database.
Load Step: Inertia Relief: Parameter Tab
In the Parameter tab, define optional parameters for the * INERTIA RELIEF card.
The supported parameters include: Orientation, Fixed, Remove, and None.
Click Update to activate the optional parameter selection in the HyperMesh database.
