HyperMesh
HyperMesh
2021
  1. Home
  2. Browsers
    Browsers supply a great deal of view-related functionality in HyperMesh by listing the parts of a model in a tabular and/or tree-based format, and providing controls inside the table that allow you to alter the display of model parts.
  3. Connector Browser
    Use the Connector Browser to view and modify connectors in the current model.
  4. Find Connectors From Parts or Links
    Locate and isolate connectors that connect the selected entities/part(s) in the Link Entity Browser using the Find option.
  • What's New
  • Get Started
  • Tutorials
  • CAD Interfaces
  • Browsers
  • Panels
  • Geometry
  • Meshing
  • Connectors
  • Model Build and Assembly
  • Model Verification
  • Crash and Safety
  • Composites
  • Model Setup
  • Morphing
  • Optimization
  • Conversion Between Solver Formats
  • XY Plotting
  • Post-Processing Analysis
Index
 HyperMesh
2021
HyperMesh
  • What's New
    View new features for HyperMesh 2021.
  • Get Started
  • Tutorials
    Discover HyperMesh functionality with interactive tutorials.
  • CAD Interfaces
  • Browsers
    • Basic Browser Operations
      Learn the basics of working with browsers.
    • Assembly Browser
      Use the Assembly Browser to manage parts and modules during the assembly building process.
    • Connector Browser
      • Link Entity Browser
        The Link Entity Browser displays all of the links that are connected using the connectors in the model.
      • Connector Entity Browser
        The middle section of the Connector Browser contains a tree view of all the connections contained in the model, and has its own set of tools similar to the ones found in the Link Entity Browser.
      • Connector Entity Editor
        Use the Connector Entity Editor to quickly view and modify attributes assigned to connector(s).
      • Query Builder
        Use the query builder to find and filter entities by building advanced filters for attributes listed in browser columns.
      • Utility Tool Set - Connector Browser
        This tool set, located at the bottom of the Connector Browser, provides tools for output of a Master Connectors File, opening specific connector-related HyperMesh panels, or utilize specialized visualization options.
      • Link Definition
        A link is a reference to a separate entity. One or more links are added to a connector. The entities to which the links refer are connected during realization.
      • Convert Style
        Convert connectors of one specific style into a different style, for example a spot connector into a bolt connector using the Convert option.
      • Combine
        Combine aligned single point connectors into line connectors or combine several aligned seam line connectors into larger one(s) using the Combine option.
      • Split
        Split spot or bolt line connectors into individual single point connectors using the Split option.
      • Position
        Place a connector in-between the center of the two farthest defined links or its source position using the Position option.
      • Add Link
        Add links (component, assembly, surface, element, tag, node) at a time to one or more connectors using the Add Link option.
      • Remove Links
        Remove links from one or more connectors at a time.
      • Update Links
        Update the attributes associated with a link, such as reconnection rule, link references, and link state.
      • Convert Links
        Existing connector links can be converted to one of the following link types: Part, Comp, or Prop. Connector link conversion requests a clear 1:1 relation between a component and a property, otherwise the conversion is not unique and will not be performed.
      • Find Connectors From Parts or Links
      • Find Connectors From Realizations
      • Find Links From Connectors
        The find parts feature in the Connector Browser context menu finds the entities/part(s) connected by specific connector(s), and isolates them in the graphics area.
    • Contact Browser
      Use the Contact Browser to create, review and modify contact interfaces and surfaces in a model.
    • Entity Editor
      The Entity Editor enables you to quickly view and edit entities in a model and correctly setup solver information.
    • Entity State Browser
      Use the Entity State Browser to set various states for entities in a model.
    • Loadsteps Browser
      Use the Loadsteps Browser to create, manage and display loadsteps (sub-cases) and the associated control cards.
    • Mask Browser
      In the Mask Browser, set the mask/unmask state for entities at the entity configuration level.
    • Mass Trimming Browser
      Use the Mass Trimming tool to create, define and realize mass entities.
    • Matrix Browser
      Use the Matrix Browser to explore the HyperMesh and HyperView data entities and export the entities to external files for further analysis.
    • Model Browser
      Use the Model Browser to view the model structure while providing full find, display and editing control of entities.
    • Model Checker
      Check the solver validity of the model, identify modeling issues, and fix modeling issues in an automatic or manual way.
    • Part Browser
      Use the Part Browser to create, organize and manage the CAE part structure/hierarchy.
    • Reference Browser
      The Reference Browser enables you to quickly understand complex relationships between different entities that constitute the model.
    • Solver Browser
      The Solver Browser provides a solver centric view of the model structure in a flat, listed tree structure.
    • Subsystem Browser
      Create, organize and manage the CAE subsystem level models using any entities.
    • Utility Menus
      The Utility menu contains options that allow you to customize the standard interface to include function buttons, radio options, and text that have HyperMesh-supplied and user-defined macros associated with them.
    • Visualization Controls
      Use the Visualization controls to change many of the visual states in HyperMesh and HyperView.
  • Panels
  • Geometry
  • Meshing
  • Connectors
  • Crash and Safety
  • Composites
    HyperMesh composites modelings.
  • Model Setup
  • Morphing
  • Optimization
  • XY Plotting
 HyperMesh
HyperMesh
2021
  1. Home
  2. Browsers
  • What's New
  • Get Started
  • Tutorials
  • CAD Interfaces
  • Browsers
  • Panels
  • Geometry
  • Meshing
  • Connectors
  • Crash and Safety
  • Composites
  • Model Setup
  • Morphing
  • Optimization
  • XY Plotting
Index
The found connectors are also highlighted in the browser making it easy to perform further operation. Find also isolates the realized welds of a connector if the realization view options button is activated in the Link browser tool set.
Find connectors from components can be accessed from the Link Entity Browser's right-click context menu.
Find Connectors From Supported Entities/Parts
  1. Ensure that the Linked Connector view option toggle () is active.
    If the realized welds of the connectors also need to be displayed in graphics then activate the button.
  2. Either:
    • Ensure that the Show/Hide button () is active in Show mode, and then click the desired link entity, or
    • Use the selector to pick the desired link entities, and then left-click the Show/Hide button.
Find Connectors Between Two or More Supported Entities/Parts
  1. Select two or more supported entities from the link entity table to find their connecting connectors.
    The entities can be easily located in the browser table list by using the Selector icon in the action mode tools. Click the button and select the entities in the graphics area to highlight it in the table.
    If the realized welds of the connectors also need to be displayed in graphics then activate the icon.
  2. Use the Link Entity Browser advanced action buttons to show or isolate the shared connectors.
