Drape Plies and Review Results
In this task you will drape the uni-directional plies.
- In the Model Browser, select the plies folder.
- Right-click and select Drape > Kinematic Drape from the context menu.
- On the Drape Calculation tab, specify the Seed Point (id=5366). This is the location the ply first touches the mold.
- Leave method set to Quadrants. This method simulates a ply which is placed on the mold at the seed point, and is then pressed to the mold uniformly in all directions. Alternatively, Linear can be used. This method simulates a ply which is placed on the mold at the seed point, is then pressed to the mold along the fiber direction in a narrow strip, and is finally pressed to the mold uniformly from the fiber strip in the matrix direction.
Click Apply.
Note: The second ply will throw a message in the bottom left of the screen, indicating that maximum shear was exceeded. This indicates that the fiber locking angle of the fabric was reached. By default, drape angles for any elements in this condition will be set to reflect a locked angle and no further action is required. Alternatively, the ply(s) can be draped again using a larger Max. shear angle in the Advanced options menu.
Review Results
- From the Review tab, visualize the Draping Mesh for the first ply, which idealizes the warp direction of the fabric.
- From the Review tab, visualize the Draping Mesh to verify identical draping mesh as in the first UD ply.
Turn on Composite Layers with Fiber Direction by clicking
on the Visualization toolbar. This visualizes fiber directions for both
The dome draping results are compared to [10] in the following image.
