Review and edit connector metadata that was created during import using the FEMSITE
Review Conn tool.
All of the supported connector metadata that can be imported is listed in the
parameter.cfg file, which can be found in the installation:
/config/parameter.cfg.
Tip: If certain metadata
is not applicable to you, create comments for them using "#". HyperMesh will ignore metadata commented with
From the menu bar, click .
In the panel area, use the connectors selector to
select one or more connectors.
Click proceed.
In the Edit params dialog, review and edit the
corresponding metadata of the selected connector(s).
Note: If you selected multiple connectors, only identical metadata is displayed.
Blank fields indicate that metadata was not identical for the selected
connectors. If metadata was not defined, field will read "not
defined".
Click Submit.
