Check Connector Connections
Check if the connection partners of connectors are available in the HyperMesh database.
Before you begin, Setup the FEMSITE Utility.
From the menu bar, click Connectors > FEMSITE > Check Connected.
After a check is performed, the number of connectors that have no existing connector partners in the HyperMesh database is reported, and failed connectors are displayed.
There is no geometrical check done if a projection is possible, only the availability is checked.
When REFMODE is set to Part, only assemblies are checked. PIDS are not checked.
