Rename a Note
If the Notes panel is not currently active, right-click on a note in the Results Browser and select Edit.
To rename a note from the Notes panel:
  1. Right-click on the name of a note in the Notes list and select Rename (from the context menu).
  2. Type a new name into the Rename dialog.
  3. Click OK.
    The note is renamed in the Notes list.
