Attach a Note to an Entity
If the Notes panel is not currently active, right-click on a note in the Results Browser and select Edit.
To attach a note to an entity:
  1. From the Notes panel, select a note in the Notes list.
  2. Under Attach to, select Entity.
  3. Select an entity from the input collector menu.
    • Node
    • Element
    • Component
    • System
  4. Select the entity.
    • Click the input collector (Node, Element, Component, or System) and select By ID.
    • Pick an entity (node, element, component, or system) directly from the model in the modeling window.
  5. Click Apply.
    The note is attached to the selected entity.
