Attach a Note to a Window
If the Notes panel is not currently active, right-click on a note in the Results Browser and select Edit.
To attach a note to a window:
  1. From the Notes panel, select a note in the Notes list.
  2. Under Attach to, select Window.
    The note is attached to the window.
