Export Files
Export the current contour result file.
  1. From the menu bar, select File > Export > Model.
  2. In the Export H3D Model dialog, enter a file name then click and browse to your working directory.
  3. Define any export options then click OK.
    Currently, only static FE result files, not fatigue result files, are supported.
