Save Files
Save all of the data in your current session.
Do one of the following:
  • From the Home tools, Files tool group, click the Save As tool.
  • Select a save option from the File menu.
Session information is saved as an *.hlf file to a default directory. On Windows, this directory is C:\Users\<userid>\Documents\Fatigue\RunHistory\<run_name>.
On Linux, the directory is /usr/tmp/Fatigue/RunHistory/
You can change the directory from the Preferences dialog.
