Rotate, Pan, Zoom, Fit, Center
Adjust your view of the model in the modeling window.
Rotate the View
Rotate the view to inspect different areas of the model.
  • Rotate the view with keyboard shortcuts and mouse controls.
    To Do this
    Freely tumble Drag the model while middle mouse clicking.
    By default, the center of rotation is determined by your cursor position when you rotate the model. When your cursor is not on the model, the center of rotation defaults to the center of the modeling window.
    Incrementally rotate Press the arrow keys on your keyboard.
  • Select a standard view by clicking on the View Controls toolbar.
Pan the View
Move the view horizontally and vertically in the modeling window.
Pan the view in the following ways:
  • Drag the model while right-clicking.
  • Drag the model while right and left clicking simultaneously.
Zoom the View
Zoom in to view specific areas of the model, and zoom out to see a more overall view of the model.
Scroll the mouse wheel to zoom the view in and out.
The center of zoom is determined by your cursor position.
Fit the View
Adjust the view to fit the model in the modeling window.
Fit the view in the following ways:
  • Click on the View Controls toolbar and select a fit option.
  • Press F on the keyboard to quickly fit the model.
