Modal FRF - Plot Response
Plot the response options.
Response File
Information from the result PUNCH file with FRF results.
Subcase
Select a subcase from the drop-down menu.
Result type
Select the response type, displacement, velocity, and acceleration.
Response ID
Select the grid ID of the response from the drop-down menu.
Direction component
Select the component of the response grid ID from the drop-down menu.
Display Options
The Display Options dialog allows you to customize the response plot, including scale, weighting, and the plot layout.
Load Response
Once the result selection options are complete, select Load Response to display the response curve.
Figure 1. NVH Utilities Browser - Modal FRF - Model tab/Plot Response subtab
Figure 2. Response curves for the FRF computed from modal results
