Modify a Curve from the View Dependencies Dialog
  1. In HyperGraph, right-click on a curve and select View Dependencies from the context menu.
    The View Dependencies dialog is displayed.
  2. The curves that you selected and all curves that define it are listed in the left panel of the dialog.
  3. The right panel of the dialog contains source information about each curve.
  4. From the left panel, select the curve you want to modify.
  5. From the right panel, select the modifications that you want to make to the curve.
  6. Click Apply.
    The selected curve is modified.
    Note: If a curve name listed in the left panel is too long, select Line wrap to wrap the name of the curve so that it fits in the panel.
