Exclude a Curve from the Tip-to-tail Calculation
  1. To remove a curve from the calculation process, select the curve(s) from the Available curves list and click the forward arrow, , to move the curve(s) to the Exclude column.
  2. To select non-contiguous curves in a list, select then first curve, then press the Control button while selecting the next curve.
  3. To add the curve back to the Available curves list, select it from the Exclude list and click the back arrow, .
