HyperGraph 3D offers a 3-D plotting environment that is fully integrated with HyperWorks, for managing, reviewing, and analyzing 3-D plots such as waterfall, surface, and 3-D line data.
Reference a Datum Plane Intersection from an XY Plot Window
From the Select application drop-down menu, select HyperGraph.
From the Define Curves panel, add a new curve.
Under Source, change the curve type to Math.
In the x= or y= fields, enter p#w#d#.vector to reference
the planes intersection of the curves.
The vector is either X or Y to select the values along the plane’s
length or height. For example, p1w1d1.y selects the plane’s
local Y values for the first datum plane in window 1 of page 1.
