Generate an XY Plot from the Datum Plane's Intersection
  1. From the HyperGraph 3D toolbar, click the Datum Planes icon, .
  2. Select a datum plane from the Datum list.
  3. Select Cross section or Clipping plane.
  4. Select the Create XY Plot tab.
  5. Under Place curve on:, select Preview plot, New plot, or Existing plot.
    Preview plot
    Creates the curve in a pop-up window.
    New plot
    Creates the curve in a new plot window.
    Existing plot
    Creates the curve in an existing plot window.
    If you select Existing plot, select an existing plot window from the tree selection.
  6. Click Apply to create the plot.
