This option allows you to perform deletions on any combination of elements of any type: 1D, 2D, and 3D.
Elements can be selected by the standard methods:
Button |
Behavior |
pick elements in the graphic window, then answer the question in the Dialog menu bar with Yes or Cancel. |
add/remove elements in the graphic window, then answer the question in the Dialog menu bar with Yes or Cancel. |
add elements by box selection (the default box is rectangular — use the SHIFT key to define a polygon box). |
remove elements by box selection (the default box is rectangular — use the SHIFT key to define a polygon box). |
pick parts in the graphic window, then answer the question in the Dialog menu bar with Yes or Cancel. |
add parts by box selection (the default box is rectangular — use the SHIFT key to define a polygon box). |
remove parts by box selection (the default box is rectangular — use the SHIFT key to define a polygon box). |
add in the selection the parts selected in the tree. |
remove from the selection the parts selected in the tree. |
clear the selection |
Once selected, elements can be deleted (
Deleting 2D or 3D elements can result in free nodes left behind (nodes are considered free if they do not belong to any other element). To remedy this, ensure that the Delete element free nodes checkbox is activated before clicking the DELETE icon. Note that deleting free nodes only applies to 2D and 3D elements, even if you have some 1D elements in your selection.
