Engineering Solutions
2021
  1. Home
  2. Browsers
    Browsers supply a great deal of view-related functionality in Engineering Solutions by listing the parts of a model in a tabular and/or tree-based format, and providing controls inside the table that allow you to alter the display of model parts.
  3. Utility Menus
    The Utility menu contains options that allow you to customize the standard interface to include function buttons, radio options, and text that have Engineering Solutions-supplied and user-defined macros associated with them.
  4. PAM-CRASH 2G Utility Menu
    The PAM-CRASH 2G Utility menu (pamcrash2G.mac) contains shortcuts and tools that help simplify PAM-CRASH 2G tasks.
  5. Tool Menu
    Use the Tool menu options to simplify safety tasks.
  6. Organize Xlinks Macro
    The XLINK Organizer macro can be used to move and arrange existing LINK type elements (PLINK, ELINK, LLINK, SLINK) to existing components.
  • What's New
  • Get Started
  • Tutorials
  • NVH
  • Squeak and Rattle Director
  • Crash
  • CFD
  • Drop Test
  • Aerospace
  • CAD Interfaces
  • Browsers
  • Panels
  • Geometry
  • Meshing
  • Connectors
  • Model Build and Assembly
  • Model Verification
  • Model Setup
  • Morphing
  • Optimization
  • Conversion Between Solver Formats
  • XY Plotting
  • Post-Processing Analysis
Index
2021
  • What's New
    View new features for Engineering Solutions 2021.
  • Get Started
    HyperWorks Engineering Solutions is a modeling and visualization environment for NVH, Crash, CFD, Drop Test and Aerospace using best-in-class solver technology.
  • Tutorials
    Discover Engineering Solutions functionality with interactive tutorials.
  • NVH
    Noise, Vibration and Harshness (NVH) is an important vehicle attribute that directly affects the customer experience.
    Use Squeak and Rattle Director tool to create evaluation lines, evaluate them and optimize the interfaces to eliminate squeak and rattle issues.
  • Crash
    The Crash application offers a tailored environment in HyperWorks that efficiently steers the Crash CAE specialist in CAE model building, starting from CAD geometry and finishing with a runnable solver deck in Radioss, LS-DYNA and PAM-CRASH 2G.
  • CFD
    HyperWorks offers high quality tools for CFD applications enabling the engineer to perform modeling, optimization and post-processing tasks efficiently.
  • Drop Test
    The Drop Test Manager is an automated solution that allows you to either simulate a single drop test or a choice of multiple iterations with the aim of finding the sensitivity of process variables like initial orientation and drop height in a typical drop test by controlling the run parameters and conditions with ease.
  • Aerospace
    Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to be compatible with this release.
    Solver interfaces supported in Engineering Solutions.
  • CAD Interfaces
  • Browsers
    • Basic Browser Operations
      Learn the basics of working with browsers.
    • Assembly Browser
      Use the Assembly Browser to manage parts and modules during the assembly building process.
    • Connector Browser
      Use the Connector Browser to view and modify connectors in the current model.
    • Contact Browser
      Use the Contact Browser to create, review and modify contact interfaces and surfaces in a model.
    • Entity Editor
      The Entity Editor enables you to quickly view and edit entities in a model and correctly setup solver information.
    • Entity State Browser
      Use the Entity State Browser to set various states for entities in a model.
    • Loadsteps Browser
      Use the Loadsteps Browser to create, manage and display loadsteps (sub-cases) and the associated control cards.
    • Mask Browser
      In the Mask Browser, set the mask/unmask state for entities at the entity configuration level.
    • Mass Trimming Browser
      Use the Mass Trimming tool to create, define and realize mass entities.
    • Matrix Browser
      Use the Matrix Browser to explore the HyperMesh and HyperView data entities and export the entities to external files for further analysis.
    • Model Browser
      Use the Model Browser to view the model structure while providing full find, display and editing control of entities.
    • Model Checker
      Check the solver validity of the model, identify modeling issues, and fix modeling issues in an automatic or manual way.
    • Part Browser
      Use the Part Browser to create, organize and manage the CAE part structure/hierarchy.
    • Reference Browser
      The Reference Browser enables you to quickly understand complex relationships between different entities that constitute the model.
    • Solver Browser
      The Solver Browser provides a solver centric view of the model structure in a flat, listed tree structure.
    • Subsystem Browser
      Create, organize and manage the CAE subsystem level models using any entities.
    • Utility Menus
      • QA/Model Utility Menu
        The QA Utility menu contains many tools to help you quickly review and clean up the quality of a pre-existing mesh.
      • Disp Utility Menu
        In the Disp Utility menu, clear temporary nodes if needed.
      • Geom/Mesh Utility Menu
        This menu contains a set of macros related to working with model geometry, as well as a set for working with FE mesh.
      • Abaqus Utility Menu
        Macros are included on the Abaqus page of the Utility menu when you load the Abaqus user profile.
      • ANSYS Utility Menu
        The macros on the ANSYS Utility menu simplify some common tasks for the ANSYS user profile.
      • LS-DYNA Utility Menu
        The LS-DYNA Utility menu contains shortcuts and tools that can help simplify LS-DYNA tasks. Set the user profile from the User Profiles option of the Preferences menu.
      • Nastran Utility Menu
        The Nastran user profile contains two macro menus on the Utility menu: Nastran1 and Nastran.
      • PAM-CRASH 2G Utility Menu
        • Tool Menu
          • Dummy Positioning Tool Start Macro
            Use this macro to position dummies.
          • Part Info Macro
            The Part Info macro summarizes a part’s statistics in a dialog.
          • Substructure Tool Macro
            The Substructure Tool macro provides several features for creating and modifying substructures.
          • RBODY Manager Macro
            The RBODY Manager is accessible in the PAM-CRASH 2G Tool menu.
          • Apply Initial Metric Macro
            The Apply Initial Metric macro applies the initial metric to the current model for simulating the inflation of airbags.
          • Organize Xlinks Macro
          • MASS Manager Macro
            Displays information about masses in the model.
          • Input Fields in the Show ID Ranges User Interface
        • Find Menu
          The Find menu contains options that help you find and visualize data.
        • Card Menu
          The Card menu contains options that help display the PAM-CRASH 2G cards in an editor.
        • Sum Menu
          The Sum menu contains options that execute the PAM-CRASH 2G summary templates and display the resulting text file in a viewer.
        • M1 Menu
          The M1 menu contains options that set the correct element or load type and enter the appropriate HyperMesh panel.
        • M2 Menu
          The M2 menu contains options that set the correct element or load type and enter the appropriate Engineering Solutions panel.
        • Conn Menu
          The Conn menu contains options that let you manage connectors in the model.
        • GES Macro
          The GES macro displays a GES Browser that lets you manage sets in the model.
      • OptiStruct Utility Menu
        The Utility menu for the OptiStruct user profile contains, in addition to the default Utility menus, three pages (Summary, FEA and Opti) of specific utilities for OptiStruct.
    • Visualization Controls
      Use the Visualization controls to change many of the visual states in Engineering Solutions and HyperView.
  • Panels
  • Geometry
  • Meshing
  • Connectors
  • Model Setup
  • Morphing
  • Optimization
    Setup an Optimization in Engineering Solutions.
  • XY Plotting
2021
  1. Home
  2. Browsers
  3. Utility Menus
  5. Tool Menu
  • What's New
  • Get Started
  • Tutorials
  • NVH
  • Crash
  • CFD
  • Drop Test
  • Aerospace
  • CAD Interfaces
  • Browsers
  • Panels
  • Geometry
  • Meshing
  • Connectors
  • Model Setup
  • Morphing
  • Optimization
  • XY Plotting
Index
The macro contains the following options:
Table 1.
Option Description
Select element: Select the element type you want to work with.
Prefix: Filter the element results by the text you type in the adjacent text box. Click Set to run the filter.
The macro contains the following buttons:
Table 2.
Button Action
Makes only the selected elements visible in the graphics display.
Select a component/part to which the selected elements will be added.
Import a component from a PAM-CRASH 2G input file.
Move an XLINK Element to a Component
  1. Select the type of link element from the Select element field.
    The list of elements of that link type are listed in the table along with the parts with which they are associated.
  2. Click component to select a component to which you want to add the selected elements.
  3. Click Apply.
    The selected elements are added to the selected component.
