HyperWorksEngineering Solutions is a modeling and visualization environment for NVH, Crash, CFD, Drop Test and Aerospace using best-in-class solver
technology.
The Crash application offers a tailored environment in HyperWorks that efficiently steers the Crash CAE specialist in CAE model building, starting from CAD geometry and finishing with
a runnable solver deck in Radioss, LS-DYNA and PAM-CRASH 2G.
HyperWorks offers high quality tools for CFD applications enabling the engineer to perform modeling, optimization and post-processing
tasks efficiently.
The Drop Test Manager is an automated solution that allows you to either simulate a single drop test or a choice of
multiple iterations with the aim of finding the sensitivity of process variables like initial orientation and drop
height in a typical drop test by controlling the run parameters and conditions with ease.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to
be compatible with this release.
Browsers supply a great deal of view-related functionality in Engineering Solutions by listing the parts of a model in a tabular and/or tree-based format, and providing controls inside the table
that allow you to alter the display of model parts.
The Utility menu contains options that allow you to customize the standard interface to include function buttons, radio options, and
text that have Engineering Solutions-supplied and user-defined macros associated with them.
The BOM Comparison tool, located on the QA/Model Utility menu, reads a generic Bill of Materials (BOM) file and provides an interface to manipulate data in the BOM and its corresponding
FE model.
The LS-DYNAUtility menu contains shortcuts and tools that can help simplify LS-DYNA tasks. Set the user profile from the User Profiles option of the Preferences menu.
The Utility menu for the OptiStruct user profile contains, in addition to the default Utility menus, three pages (Summary, FEA and Opti) of specific utilities for OptiStruct.
Perform automatic checks on CAD models, and identify potential issues with geometry that may slow down the meshing
process using the Verification and Comparison tools.
Find elements that are connected to displayed elements using the Find Attached (Tied)
option.
Tied elements are those that are tied to each other, but are not attached physically.
This option differs from the Find Attached option, which returns elements that are
physically attached to each other via common nodes.
Find Attached (Tied) is available for the LS-DYNA user
profile on the QA/Model Utility menu.
The relationship between tied elements is defined using the following
CONTACT keywords:
Element Type
Contact Keywords
ContactSpotWeld
*CONTACT_SPOTWELD
NodesToSurface
*CONTACT_TIED_NODES_TO_SURFACE
*CONTACT_TIEBREAK_NODES_TO_SURFACE
*CONTACT_TIED_SHELL_EDGE_TO_SURFACE
SurfaceToSurface
*CONTACT_TIEBREAK_SURFACE_TO_SURFACE
*CONTACT_TIED_SURFACE_TO_SURFACE
SlidingOnly
*CONTACT_SLIDING_ONLY
ConstdTieBreak
*CONSTRAINED_TIE-BREAK
XtraNode
*CONSTRAINED_EXTRA_NODES_NODE
*CONSTRAINED_EXTRA_NODES_SET
TiedNodes
*CONSTRAINED_TIED_NODES_FAILURE
ConstRigidRbody
*CONSTRAINED_RIGID_BODIES
Features
Find Attached (Tied) returns any tied elements connected via TIED_CONTACTS as
defined using LS-DYNA.
You can perform a Find Attached (Tied) operation on one or more displayed
elements or components.
Element input and output is based on dimension as follows:
Input (displayed)
Output (attached or tied)
1D/3D elements
2D elements
2D elements
1D/3D elements
2D elements
2D elements
Note: For ContactSpotweld, the 1st and 2nd use
case is valid.
Use Cases
Use Case 1:
Two independent beam nodes are connected to a common layer.
Result:
If you start with the green shell and 1D beam in image 1., then the Find
Attached (Tied) operation returns the elements in the following
sequence:
Figure 3.
Figure 4.
Figure 5.
Use Case 2:
A common node between two 1D elements.
Result:
If you start with the 1D beam in image 1., then the Find Attached (Tied)
operation returns the elements in the following sequence:
Figure 6.
Figure 7.
Figure 8.
Note: The Find Attached (Tied) option works with displayed elements only.
