Context Menu
Provides a variety of options for working with the Model Checker.
Access
Right-click on empty space or on a check, check folder, or failed entity to display the context menu.
Option | Description |
Load file | Loads a new configuration file. It can either be a legacy model checker configuration file or a configuration file saved in the new XML format. |
Add file | Appends the configuration file on top of the existing checks. |
Run | Runs active checks. |
Apply auto correction | Applies auto correction and re-runs active checks. |
Investigate | Opens card edit or opens the appropriate panel as defined in the Investigate field. You can make modifications manually on the failed entity. |
Create Check | Creates a new check. |
Create Folder | Creates a new check folder. |
Create Correction | Creates a new correction. |
Show | Displays failed entities in the graphics area if they are currently hidden. |
Hide | Turns off the visibility of the failed entities in the graphics area if they are currently visible. |
Isolate Only | Displays only failed entities in the graphics area and hides all of the other items. |
References | Opens the Reference Browser and displays the relationship of the selected card(s) or entity(s) to other entities in the model in a hierarchical tree structure. |
Delete | Deletes failed entities from the session. |
Delete Check | Deletes selected check from the session. |
Review | Invokes Review mode, which displays selected entities irrespective of their display state, masked, or active state Entity State Browser. |
View |
Elements and nodes are not displayed directly in Model Checker browser. This option opens a new window that shows lists of failed elements/nodes associated with the check. Only checks with less than 1000 failed entities have this option enabled. To increase the limit set the HM_MODELCHECKER_LIMIT_VIEW environment variable to the required limit. |
Save Config File | Saves active checks into an .xml file. |
Export Results | Writes count of failed entities against each check into a text file. |
Export Failed checks | Writes count of failed entities against each check for which "User Status" is set to FAIL. |
Export detailed CSV report | Writes detailed report with failed IDs against each check into a .csv format. |
Show only run checks | Filters Model Checker browser to show only checks that are run. |
Show only failed checks | Filters Model Checker browser to show only checks that have failed entities associated with them. |
Show only active checks | Filters Model Checker browser to show all active checks. |
Show all checks | Shows all available checks. |
Expand All | Expands all folders. |
Collapse All | Collapses all folders. |
