Group parts based on size and shape.
After the check, groups are created under the Part Browser/Part
Set Browser. To execute the classification, parts are mandatory. Select the root
part from the Verification Browser or the Comparison Browser and run Classify.
From the Verification Browser/Comparison Browser, right-click and select from the context menu.
From the Method drop-down menu, select either AI or
Shape.
In the Similarity (%) field, type the desired same shape match%. The default is
50%.
In the Tolerance field, type the search tolerance to use to find matching
entities. The default is 0.1mm.
In the Max Area field, type the maximum area to search.
In the Min #Surface field, type the minimum number of surfaces to use.
Click Run.
