Create and Edit Curves
Use the curve editor to create and plot XY curves.
From the Model ribon, Plots
tools, click the Curves tool.
Alternatively, you can right-click in the Model Browser and
create a new Curve entity.
Figure 1.Figure 2.
Create a new curve by clicking
in the upper left corner of the editor.
A new curve entity will be added to the entity list. -
To rename the curve, right-click on the existing curve name and select
Rename from the context menu.
The curve is renamed and issued a unique ID number.
You can choose whether to display the curve in the graph by clicking
in front of the named entity.
To delete a curve, select the appropriate curve and click the trashcan icon
), or highlight the name of the curve and select Delete from the context menu.
To plot the curve:
- Click the Table tab on the middle left-side of the editor.
- Click into the first cell of the table in row 1 under the X column and type a value for the x-coordinate.
- Press the Tab to move to the Y column and type a value for the y-coordinate.
Press the Tab again to move down to the next
row and continue entering values as necessary.
The curve is plotted in the editor.
You can change various attributes of the plot by clicking the
Property Editor tab:
- Visibility
- When checked, displays the curve.
- Layer
- When report templates are overlayed, each overlayed curve is stored in a different layer.
- Reference
- The curve (and shading, if areas are shaded) moves behind the grid lines of the plot, so that the grid lines are visible over the curve/shading. Autofit does not apply to the curve.
- Show Label
- Displays the name of the curve in the upper-right corner of the graph.
- Label
- The name of the curve.
- Show Label Prefix
- Displays a prefix before the name of the curve in the label.
- Show Label Suffix
- Displays a suffix after the name of the curve in the label.
- Line Style
- Options for displaying various line types.
- Line Color
- Change the color of the curve.
- Line Thickness
- Change the thickness of the curve.
- Shade Area
- Provides options for shading parts of the graph in relation to the curve.
- Symbol Style
- Provides options for adding a symbol to the curve label. You can set the style, color, frequency, and size of the symbol.
