Solver Encryption Entities
The encryption of solver entities is used to translate entity data into an undisclosed language.
Support of encrypted solver entities will allow you, for example, to manipulate encrypted dummies within the Dummy Browser.
You can view encrypted entities from the Model Browser, Solver Browser and References Browser. If an entity is encrypted, then its corresponding attributes will not be exposed in , and curves cannot be reviewed or edited in the Curve Editor.
Undo and redo encryption actions made in HyperMesh using Undo/Redo.
LS-DYNA
Encrypted material and curve entities can be imported and exported.
PAM-CRASH 2G
Secure MATER, PART, FUNCT, and PLY can be imported and exported.
Radioss
Property and failure entities can be imported and exported.
