Name
The name of the FBD Section Group.
ID
The ID of the FBD Section Group.
Color
The color of the FBD Section Group.
Intersect entity ids
Select elements of interest along the node path for the FBD Section
Group.
System definition
Defines the system used to plot results.
System
Available when the system definition is set to User defined. Selects
a coordinate system to plot results.
Orientation Vector
Available when the system definition is set to Direction based.
Defines the orientation vector to define the XY plane.
