Launching SnRD Post
The steps to launch SnRD Post-processing module are mentioned in the following section.
- Launch HyperView 2021 from installed location.
- Select File > Load > Preferences.
Select Squeak & Rattle and click
Load. This creates SnRD menu in the HyperMesh
window.
Click Directors > SNRD
Figure 2.Figure 3.
The functions and operations to be done in each tab are explained in the following sections. You have to start from Post Processing tab to load the files and evaluate the results.
Once SnRD Post tab is active, click
against Model File.
A file browser option opens. Browse and selectTutorial_IP_SNR_Model.fem
from the folder which was created during Process Parameters step. - Since the Pre-output CSV file is located in the same folder, this will be picked automatically by SnRD.
- After selecting the required files, click the required tab to continue with the processing.
