Remesh Tessellated Models
Use the Mesh to create new surface mesh on converted geometry.
The Mesh tool works for tessellated geometry. If the input is b-spline geometry, first convert to discrete geometry using the Convert tool.
Imported Nastran .stl files can consist of poor quality mesh. After converting to discrete geometry, it's helpful to remesh the model. The rest of the options used to edit geometry work better on a good quality mesh.
Note: You have the option to retain the surface mesh you create here when performing batch meshing.
  1. From the Geometry ribbon, click the Mesh tool.
  2. On the guide bar, click to define meshing options.
  3. Select surfaces.
  4. Click Mesh on the guide bar.
