Use the Wrap: Run tool to
create wrap from selected parts.
The
Wrap tool works for tessellated geometry. If the input
is b-spline geometry, first convert to discrete geometry using the Convert tool.
If local and proximity controls are defined, they will override the default settings
defined in this tool.
From the Geometry ribbon, click the tool.
Select parts to wrap.
Input global size settings in the dialog.
Click
to view advanced wrapping
options.
Click Run.
After wrapping, the generated result is placed in the first selected
part and the part is renamed as “CFD wrap 1”. Since the wrapped form is
manifold, results can be one or multiple solids. The input selection is removed
in order to avoid duplication.
