Spin Geometry Spin surfaces, nodes, or lines around a defined axis. Note: This feature is not supported for a model with discrete geometry. From the Geometry ribbon, Drag/Spin tool group, click the Spin tool. Figure 1. Optional: On the guide bar, click to define additional options. Choose between Surfaces, Nodes, and Lines using the guide bar selector. Select surfaces/nodes/lines in the modeling window. Click Spin Axis on the guide bar. Left-click to place the axis. Spin your selection by dragging the slider or entering an angle in the microdialog. Tip: Click in the microdialog to define the direction of the spin axis using the Vector tool. Once a direction has been defined, press Esc. On the guide bar, click one of the following: - Save changes and stay in the tool - Save changes and close the tool - Exit the tool without saving changes
