Combine Solids
Use the Boolean: Combine tool to connect two or more solids together, retaining all of the material in both.
  1. From the Geometry ribbon, click the Boolean > Combine tool.
  2. Optional: On the guide bar, click to edit the tolerance value.
  3. Select solids in the following ways:
    • Click Find on the guide bar to detect solids within the given tolerance.
    • Manually select individual solids by left-clicking.
    • Click and drag to draw a window. Only intersecting solids in the enclosed region are selected.
  4. Review each intersecting solid by clicking and on the guide bar.
  5. Combine solids in the following ways:
    • In the modeling window, hover over individual intersecting solid pairs and left-click to combine.
    • On the guide bar, click Combine All to combine all of the intersecting solids.
Combine Solids Using the Context Menu
Quickly connect overlapping or intersecting solids without opening the Boolean: Combine tool.
  1. Navigate to the Geometry ribbon.
  2. While in idle mode, select the solids to combine.
  3. Right-click in the modeling window and select Edit > Connect from the context menu.
    This has the same effect as using the Boolean: Combine tool with the Keep common interface option active.
